09-28-2009, 09:00 AM   #11 (permalink)
Beoweolf
Re: anyone know about fuel system on Late model Bronco?
Originally Posted by FEandGoingBroke View Post
That's great news! Please make sure that if you have a frame mounted pressure pump that you ensure every 6 months or so that the Electrical connections (if the male female blade type) to ensure they are tight.
They like to get warm with use and lose their grip then start arcing and giving poor pressure up top because they turn on and off with every other bump in the road.
FE
...the later model (95-96, fer shure) have only the intank pump, the factory deleted and removed the second frame mounted fuel pump, from the late 80's and up models - might be why the damn thing was so expensive (and tricky to diagnose). Lots of cameo between the fuel pump and computer. Makes you wonder how many PCM's have been replaced unnecessarily when the pump was the real cause?
The sender unit, fuel pump and sensors for the computer are all in a drop-in unit. All the lines are either steel or flex-line which are braided/covered with neophrene... If this comes up again - I may turn it into a trail-only rig and start bypassing stuff.
09-28-2009, 09:11 AM   #12 (permalink)
Cool! I got a temperamental 88 Bronco II here that I am getting a new inertia switch for....
Honor!
Can I swap an early model 302 crank to a late model roller 5.0 block 2fast4u All Ford Techboard 7 02-17-2008 11:06 PM
Late model seats in early model mustangs fordfreak65 All Ford Techboard 7 08-25-2003 01:29 PM
Will late model PS pump work with early system? thecougarguy All Ford Techboard 10 06-10-2003 08:58 PM
questions on using late model motor in early model car jimbo All Ford Techboard 4 07-26-2002 01:55 AM
late model to early model engine swap jackor All Ford Techboard 2 07-16-2002 04:52 PM
