09-20-2009, 05:45 PM   #1 (permalink)
My427stang
EEC-IV question, ACT thread size
Does anyone know the thread size of the ACT (IAT) for a 90's Mustang? Its close to 3/8 NPT but it uses an o-ring to seal, so it seems like its straight thread.
I measured .655 diameter and 4 threads per .2 inches (20 per inch) but it doesn't seem to match anything. It is smaller than O2 sensor threads.
70 Sportsroof, 427 FE/489 cid, TKO-600, 3.70, A/C. Currently undergoing full MAF port EFI conversion with CnC ported Victor/1200 cfm throttle body. Stay tuned!!!
09-20-2009, 09:00 PM   #2 (permalink)
Re: EEC-IV question, ACT thread size
you mean the threads for the two Torx head screws?
I believe they're 6mm X 1.0 pitch.
Honor!
09-21-2009, 04:01 AM   #3 (permalink)
My427stang
No, I mean the thread size for this
It looks like pipe thread, but it seals at the top with an o-ring, pipe thread is generally tapered and you don't bottom it all the way out
09-21-2009, 07:17 AM   #4 (permalink)
pass1over
i used a 3/8 npt tap and it threaded right in, grey permatex the threads and gtg
'08 Infiniti G37S daily driver
stroked EFI '66 Mustang weekend fun
pass1over is offline   Reply With Quote
09-21-2009, 08:09 AM   #5 (permalink)
gbic1
Not supposed to be O ring there. I was at the dealer when fuel injection came out till late 90s and Ford never use O ring just pipe dope.
1964 Galaxie 428
1966 Mustang 302
1967 Cougar 390
1968 F250 Camper Special 390
gbic1 is online now   Reply With Quote
09-21-2009, 09:18 AM   #6 (permalink)
Get some pipe threads and test it by hand, but 4 threads per .2" is 16 threads per inch which isn't pipe thread and it puts you just under 11/16" which is nearly spot on for a 17mm by 1.25...
It's not pipe threads....
Remember if it's a two pin connection the body of the unit needs to be grounded in order to function properly before putting any kind of sealer on it that might cause a poor ground between it and the manifold. That signal needs reference points and the ground is one if them.
3 wire connections usually carry the ground from the ECM with them so sealant isn't a bother.
Honor!
11-14-2009, 05:17 PM   #7 (permalink)
stvrrr
3/8 NPT.. I just tapped my Explorer intake for one. Fits like it should!
Steve 64 Fairlane S/C 289 lentech AOD 8.8 strut front suspension
stvrrr is offline   Reply With Quote
EEC-IV question, ACT thread size My427stang Mustang Pages (1979-1995) 0 09-20-2009 05:36 PM
thread size gt40 head kavanaghmotorsports Home Porting Cylinder Heads 1 09-03-2009 12:04 AM
Stud Base thread size on AFR 165? teyerdhal All Ford Techboard 0 10-05-2008 06:27 AM
fuel pump thread size SixtyEightCoug All Ford Techboard 1 04-13-2006 04:19 AM
c6 converter stud thread size fogged408w All Ford Techboard 2 05-03-2004 05:07 AM
