10-27-2009, 10:54 AM   #1 (permalink)
71fordf100
Timing Qs on new EFI Swap
I am new to this forum so I apoligize in advance if my Qs have been covered before. I am finishing my EFI conversion and am having a little issue with timing/running.
Specs - .030 overbore, E303 cam, stock H.O. intake and MAF, L1C EEC and a MAF converted Crown Vic. harness.
Prob - With the SPOUT disconnected I can get the engine started and set the timing (currently 10 BTDC) so that the engine runs. When I connect the SPOUT the engine will continue to run for some time and seemingly well but when I shut it off it is very hard to restart. I mean really hard. I can sometimes get it to crank but most times I have to disconnect the SPOUT to restart.
This is my first EFI conversion (and this little set back has not discouraged me from my next) so I am open for suggestions. One thing that I do need to mention is I may only be supplying 8-9vdc to the TFI on pin 3 which is the 12v Start Only.
Thanks,
71fordf100 is offline   Reply With Quote
64 260 timing case broken what else will swap gtnrb71 All Ford Techboard 2 09-21-2009 05:41 PM
Timing cover swap and mechanical fuel pump ctfortner All Ford Techboard 8 07-01-2009 11:10 AM
timing chain versus timing gears FALCONERR68 All Ford Techboard 22 05-13-2008 08:37 PM
Timing chain cover swap (302) in vehicle, how difficult? xc600 All Ford Techboard 6 11-08-2007 07:41 PM
how to get the correct distributor timing on a 302 engine with a timing light darkstage13 Truck Forum 0 11-26-2006 03:55 AM
Probe Industries
