10-29-2009, 02:12 PM   #1 (permalink)
dutchlincoln79
calculating injector size?
Hello,
I'm reading-in about my EFI 460 project, and wonder something.
The stock 460 injector size is 24Lbs, and goes to somewhat 360 horses.
The next step is 30Lb, wich has a potential of 450 horse.
Now, this is at 90% duty cyle max.
Ther is naturally a sort of maximum injector size, else everybody would have fitted 100Lb injectors, right? Minimum size incurs idle and low rpm drivability.
As i intend to make a grunt low-rpm power torquey engine, this is important to me.
How do i determine my max. injector size?
I intend to idle at 400-500Rpm, and have a highway cruise rpm of about 1500Rpm max.
guessed max. overall RPM should be around, let say 5K rpm's.
So, range varying from 1-10.
Any info about the injector size?
I was thinking of 30 or 39Lb injectors, and in this case, are NOT a fan of bigger is better. I rather have it correct then too large...
Info highly appreciated, thank you
[url=http://imageshack.us][img]http://img222.imageshack.us/img222/2818/bannerbi0.jpg[/img][/url]
dutchlincoln79 is offline   Reply With Quote
10-29-2009, 03:16 PM   #2 (permalink)
pass1over
Re: calculating injector size?
RC Fuel Injection
'08 Infiniti G37S daily driver
stroked EFI '66 Mustang weekend fun
pass1over is offline   Reply With Quote
10-29-2009, 03:26 PM   #3 (permalink)
decurion
Stan Weiss' - Electronic Fuel Injector (EFI) Flow Data Table
-Eric
65 Comet wagon, 60% of the time it works every time.
[<a href=http://i10.photobucket.com/albums/a142/1strealjeep/Comet%20pics/Cometfront-1.jpg] target=_blank>http://i10.photobucket.com/albums/a1...etfront-1.jpg]</a>
decurion is offline   Reply With Quote
injector size for 500+ HP 347? tlyndoe Stroker Engines 2 09-28-2007 07:42 PM
injector size? dtitus Late Model EFI Techboard 3 12-04-2003 02:11 PM
injector size? dtitus All Ford Techboard 2 12-04-2003 02:04 AM
injector size deleted3 All Ford Techboard 3 07-21-2002 08:20 PM
Injector size deleted3 All Ford Techboard 3 05-25-2002 10:25 PM
