11-05-2009, 03:52 PM   #1 (permalink)
ads63
92' 351 missing under acceleration but only when warm (EGR?)
92’ 351 runs great when cold but misses under acceleration when warmer up.
Mechanic read the codes and said EGR valve and/or sensor came up.
He seemed to have no idea if this would fix the missing when warm problem.
Could EGR valve or EGR sensor cause this warm only missing problem?
If not any other ideas what I could check?
Thanks!
ads63 is offline   Reply With Quote
11-05-2009, 04:57 PM   #2 (permalink)
mustang42782
Re: 92' 351 missing under acceleration but only when warm (EGR?)
Un plug the EGR and take it for a drive, no miss, bad EGR, Deal is tho, if the EGR is bad it usually shows up as a shutter or surge at cruising speeds.
11-05-2009, 05:47 PM   #3 (permalink)
83broncodude
bad egr can also cause an erratic idle. We have gone through 3 or 4 egr valves on our 88 351w, they seem to be a normal wear item. one about ever 60k. hook a vacuum pump to it and see if it holds, is another easy way to test.
one thing is that the egr is only activated when up to operating temp so it could be your problem. but i would test before dropping the money to get one, pretty expensive and I only recommend a stealer ship factory part, they last the longest.
83 FULLSIZE Bronco - 357W Comp Extreme 4x4 cam. Edelbrock Performer Intake and 600cfm Toilet Bowl.
83broncodude is offline   Reply With Quote
11-05-2009, 08:49 PM   #4 (permalink)
ads63
Here are the error codes
The setting codes are 327 and 328 in continuous memory.
Key on engine off and key on engine running have no codes set.
Both codes indicate that the EGR system position sensor circuit is below the minimum voltage at times.
92’ 351 missing under acceleration (but only when hot) ? ads63 All Ford Techboard 10 09-05-2009 03:49 PM
acceleration wildman1982 Mustang Pages (1979-1995) 5 06-21-2009 07:32 AM
Acceleration 92LX302 All Ford Techboard 4 05-19-2009 09:12 PM
Acceleration deleted2 The Garage 2 04-09-2004 02:33 PM
Acceleration probs....? skamaniac All Ford Techboard 3 05-05-2003 06:22 PM
