Remember this, when installing the side glass. Vent windows first. Fit them and then the door windows. The rear windows are the last to adjust. I even tried paying a body shop to adjust them and they screwed them up worse then I had and ended up redoing them myself.
One last thing. I tried to mark all the bolts and nuts prior to glass removal so I could put everything back in it's original place. I forgot that the door were readjusted so it screwed everything and it didn't work. MAKE SURE TO INSTALL THE WING WINDOW AND THE THEN THE WEATHER STRIPPING THAT GOES AROUND THE WING WINDOW AND DOOR BEFORE CONTINUEING ON IN INSTALLATION. The weatherstripping will make the door fit differently. Actually pulled the pin stripe between my two colors off by an eighth of an inch. Good luck.
64 Galaxie 500 XL (constantly morphing)
<font size=-1>[ This Message was edited by: gbeeler on 3/10/07 2:26am ]</font>
