03-21-2008, 10:09 PM   #41 (permalink)
gotyurback
Re: My Comet Project
Finally started back up on the Comet. I was happy to have the exhaust finished, I used Flowtech terminator series mufflers. They are a thad bit quiet compared to Flow Master 40 serie (which is what I may switch back to). I didn't want to run the exhaust to the bumper so i had them dumped just past the rear end.
1969 Ranchero 500 351W
1963 1/2 Galaxie 500 XL 390FE
1964 Comet Caliente 347 EFI
1967 Mustang 289
1954 2dr Customline
gotyurback is offline   Reply With Quote
04-08-2008, 10:16 AM   #42 (permalink)
gotyurback
Update: Well after installation of the exhaust, I can hear a roaring sound. At frist I thought it was coming from the rear of the engine, but the second I pushed the clutch pedal in, the noise stopped. So I guess I will drop it down and change the clutch release bearing.
1967 Mustang 289
1954 2dr Customline
07-02-2008, 10:12 AM   #43 (permalink)
fredsmailes
I wonder if that Comet is in the paint booth?
Fred
fredsmailes is offline   Reply With Quote
07-04-2008, 04:51 PM   #44 (permalink)
gotyurback
Not yet Fred, I got side lined a bit on a 67 Mustang that I sold to a buddy, then I bought it back because he couldn't finish it. But I did finally get the clutch bearing replaced, changed the headliner to gray, and won a front windsheild on Ebay (just today), so Next week I plan on dropping a 5.0 HO engine and AOD trans into the Mustang, then it's off the the paint and body shop for the comet.
1967 Mustang 289
1954 2dr Customline
09-07-2008, 11:13 AM   #45 (permalink)
gotyurback
Comet Update: I have been driving the Comet in Primer for the past month, working out all the bugs. It has been getting around 25mpg (provided that I don't put my foot in it). Damn this thing is fast. I am sending the 67 mustang to the body next week, then I will send the Comet after that.
1967 Mustang 289
1954 2dr Customline
07-17-2009, 09:45 PM   #46 (permalink)
gotyurback
Got a few things done to the Comet. Wheels and dropper it in the front 2.5 inches. Still trying to get everything completed before I can send it to the paint and body shop. Here are a few pics with my new wheels and drop.
ID:	8895   my-comet-project-comet101-4-.jpg.jpg
ID:	8896   my-comet-project-comet-update.jpg
1967 Mustang 289
1954 2dr Customline
10-04-2009, 09:06 AM   #47 (permalink)
gotyurback
Been having so much fun driving the comet that I have not slowed down enough to get it painted (that and the million and one other projects). Well I ran into a small set back, bent a valve on the right bank (I was in her pretty good) keeper let go. Damage was a bent valve, hair line crack in the valve guide. At least it don't knock a hole in the piston.
1967 Mustang 289
1954 2dr Customline
10-27-2009, 06:34 PM   #48 (permalink)
J-Roc
Great work man! Where did you get your rear replacement qarter panels from? Did you fab them up?
J-Roc is offline   Reply With Quote
11-01-2009, 05:14 PM   #49 (permalink)
gotyurback
Finally back on the road again. As it turns out it's not ok to turn a small block 6500 with .542 lift and 85 psi at the seat. It just amazing that I didn't tear this engine up sooner. After removing the head taking it to the machine shop, the only damage was a bent valve and hairline crack in the valve guide. I decided to check the springs on the driver side head and it was 75 psi at the seat. I bought this engine already running out of a 93 cobra didn't think to check everything since it was in a running car (my mistake). Well everything is back together and she's running very good. here are a few more pics.
my-comet-project-comet6.jpg   my-comet-project-comet3.jpg   my-comet-project-comet4.jpg
1967 Mustang 289
1954 2dr Customline
name for my comet rustedduster Falcon Pages 9 08-03-2008 09:07 AM
new project \"project: unFair-mont\" eliteman76 The Garage 5 04-04-2007 10:18 PM
61 comet V8 new to this... Gripstang Falcon Pages 9 09-18-2003 01:33 PM
Finally!! The Comet Project is off the ground! BFXcomet All Ford Techboard 1 04-17-2003 09:53 PM
