09-22-2007, 10:25 PM   #11 (permalink)
F15Falcon
Re: '27 Track T Paint and Assembly
I don't see a problem with it in this car because of the weight. I pulled this box from a salvage yard 3500 pound car, and it didn't crack in all it's years on the street, so surely not in it's new life. The pitman arm doesn't extend any further out in this application than it did in it's stock form, now if this was a true center steer car, a pillow block would be needed.
10-08-2007, 09:06 PM   #12 (permalink)
F15Falcon
Been at it pretty much every day for 3 weeks, here is some of the progress:
The dash is a simple aluminum plate with only the basics.
(Click Thumbnail #1)
I used a Ford 40 amp generator because it looked more appropriate.
(Click Thumbnail #2)
The headlights are Guides off a White firetruck.
(Click Thumbnail #3)
The headers are Schoenfelds that are made for an IMCA modified, but work quite well here. The valve covers are from an '85 Mustang, but they look as traditional as the Corvette covers the Chevy guys use.
(Click Thumbnail #4)
The coolant recovery tank is a 12" long piece of 2" copper tubing with a couple of core plugs silver soldered on.
(Click Thumbnail #5)
The fuel pump is from a '64 Fairlane with a 260 V-8. It has the integral fuel filter that really simplifies the fuel system.
(Click Thumbnail #6)
The distributor is an N.O.S. Mallory dual point bought off the 'Bay for $20.00. The intake is an old Edelbrock F4B, and the carb is an Autolite 2100. Yes the fuel line is copper, and it will be just fine.
(Click Thumbnail #7,8,9,10 & 11)
27-track-t-paint-assembly-pa050595.jpg   27-track-t-paint-assembly-pa050596.jpg   27-track-t-paint-assembly-pa050597.jpg
27-track-t-paint-assembly-pa050598.jpg   27-track-t-paint-assembly-pa050599.jpg   27-track-t-paint-assembly-pa050600.jpg
27-track-t-paint-assembly-pa050601.jpg   27-track-t-paint-assembly-pa050602.jpg   27-track-t-paint-assembly-pa050603.jpg
27-track-t-paint-assembly-pa050604.jpg   27-track-t-paint-assembly-pa050605.jpg
11-02-2007, 12:00 AM   #13 (permalink)
mdnangl
Thumbs up Re: '27 Track T Paint and Assembly
I love the way this Track T is coming along. A lot of thought and some really good ideas in this ride!!!
I going to keep an eye on this assembly!!
Charlie
as the clock strikes midnight...
I didnt red light, the tree was slow!!!
mdnangl is offline   Reply With Quote
12-03-2007, 08:20 PM   #14 (permalink)
F15Falcon
Got the car running, and I am in the process of finishing it up.Here is some of the latest progress:
The body is back on:
Got the exhaust done:
Model A horn bolted on:
Cal Custom air cleaner scoop installed:
A thermostatically controlled choke doesn't hurt, it works like a charm:
The gas pedal and horn button. The gas pedal "spoon" is a real spoon. All three pedals pivot on the same bolt with nylon bushings.
(Click Thumbnail #7)
Most of the interior is installed:
(Click Thumbnail #8)
Fuel line and oil pressure lines connect at this bulkhead:
(Click Thumbnail #11)
The engine has to have a good ground:
(Click Thumbnail #12)
The spring/wishbone connection:
(Click Thumbnail #13)
All the brake lines connect at bulkhead fittings:
(Click Thumbnail #14)
The tranny crossmember:
(Click Thumbnail #15)
The starter is a late model PMGR unit:
(Click Thumbnail #16)
Exhaust bracket, I tried to drill as many items as I could:
(Click Thumbnail #17)
The panhard bar is adjustable at both ends:
(Click Thumbnail #18 & 19)
Pitman arm:
(Click Thumbnail #20)
Undercarriage:
(Click Thumbnail #9 & 10)
The Hollywood Wheel Disc 15" x 5" front wheels were painted white:
27-track-t-paint-assembly-pb300731.jpg   27-track-t-paint-assembly-pb300732.jpg   27-track-t-paint-assembly-pb300733.jpg
27-track-t-paint-assembly-pb300734.jpg   27-track-t-paint-assembly-pb300735.jpg   27-track-t-paint-assembly-pb300737.jpg
27-track-t-paint-assembly-pb300738.jpg   27-track-t-paint-assembly-pb300739.jpg   27-track-t-paint-assembly-pb300740.jpg
27-track-t-paint-assembly-pb300741.jpg   27-track-t-paint-assembly-pb300744.jpg   27-track-t-paint-assembly-pb300745.jpg
27-track-t-paint-assembly-pb300746.jpg   27-track-t-paint-assembly-pb300747.jpg   27-track-t-paint-assembly-pb300748.jpg
27-track-t-paint-assembly-pb300749.jpg   27-track-t-paint-assembly-pb300750.jpg   27-track-t-paint-assembly-pb300752.jpg
27-track-t-paint-assembly-pb300753.jpg   27-track-t-paint-assembly-pb300754.jpg
12-03-2007, 08:54 PM   #15 (permalink)
ford4v429
Man...excellent choices on the nostalgia parts- you got a lot of neat stuff on there and it all 'works' great. the old distributor and generator are a very unusual thing in these transistorized days- but a very cool touch...that cars gonna draw a crowd wherever you take it, and I bet a lot of rodders from the '60s will be drooling all over it
Confidence: that feeling you have just before you realize the mess you've gotten yourself into...
http://www.hometown.aol.com/ford4v429/gal1.html
ford4v429 is offline   Reply With Quote
12-04-2007, 04:38 PM   #16 (permalink)
migg400
looks like its coming together very well. good choice in colors!
excellente'
1967 mustang fastback 418W EFI 5.spd
1990 7-up convert. lx 347 stroker 5.spd
2004 mustang gt bone stock 5.spd
migg400 is offline   Reply With Quote
'27 Track T Paint and Assembly pics: F15Falcon Street Rod Forum 10 12-10-2007 06:46 PM
Strip paint for repainting?? or prep really well and paint over??? sharpshot71 All Ford Techboard 15 08-23-2006 10:02 PM
9\" assembly knifeman85 All Ford Techboard 13 07-09-2003 03:31 PM
Track rule at Carlsbad Track, do i pass this "Neutral Safty Switch" Rule? andysam All Ford Techboard 5 05-21-2002 01:19 PM
Horn assembly Galaxie Pages 0 12-31-1969 04:00 PM
