12-13-2007, 10:13 PM   #1 (permalink)
cccdjb
Thumbs up Pushing for the summer....
Trying to get this beast together before this summer. My friend and I just finished bending and welding the cage in over the last month or so. I will be painting the cage this weekend. (Hammered Rustoleum in a pint can)
The cage is not so much for drag racing (cuz I know I won't be doing 9.99 or better), but more for the road course. Although it certainly doesn't hurt to be safe. My family will appreciate it. It does add a little extra weight, but these '65 Mustang coupes are so light anyway, it might actually help to hook up. No door bars yet, as I don't have full race seats. If I keep the seats I have, I'll have to bring the bars out into the door. Not ready to hack the car up completely just yet. Gotta think about that one. Maybe get a race seat and a bolt in door bar, hey, that's it. See, just writing this gave me a good idea.
The engines running, and I have been terrorizing the neghborhood trying to work out as many kinks as I can before taking it to the track.
No real WOT testing yet, accept a couple of black marks in a few places in my subdivision.
cccdjb is offline   Reply With Quote
12-13-2007, 10:43 PM   #2 (permalink)
Re: Pushing for the summer....
She looks SPECTACULAR! Kudo's to you!
12-13-2007, 10:53 PM   #3 (permalink)
cccdjb
Thanks FE. It's only taken 18 years....
12-13-2007, 10:53 PM   #4 (permalink)
67stang
I'm digging it! Been wanting to do a cage in my car for years now.
Editor
12-13-2007, 11:00 PM   #5 (permalink)
Mikelonis
Yes, many Kudos.
12-14-2007, 04:32 AM   #6 (permalink)
boss302isback
thumbs up
Rather Be Blown
"Remember...Ford does things exactly a certain way....except sometimes!"
Cheap, Fast, and Good...you can only have two :'(
boss302isback is offline   Reply With Quote
12-14-2007, 05:30 AM   #7 (permalink)
Huskinhano
Nice project! What are your engine/suspension specs?
Huskinhano is offline   Reply With Quote
12-14-2007, 07:40 AM   #8 (permalink)
18 years... WOW!
12-14-2007, 08:27 AM   #9 (permalink)
cccdjb
Smile Re: Pushing for the summer....
Originally Posted by FEandGoingBroke View Post
18 years... WOW!
Some history:
My Dad bought the car for me in So. Cal. in 1987. I drove it until 1989 when I met my girlfriend after moving to Alabama, she's been my wife now for 18 years. (Humm, notice the coincidence.)
I was 17 she was 21. Dad didn't like me dating an older woman. I moved in with her, he threatened to sell the car, of which my friend and I had just rebuilt the 302 in it. I made up some story about how something was wrong with the engine. Removed the engine, sold it. Got married. Car stayed at parents house in Alabama while my wife and I moved to ATL, GA and started a family (which now includes 16 yr old son, 13 yr old son, 8 yr old daughter, and a 4 yr old son). We then moved to Tallahassee, FL for a few years, finally got the car down to Florida, then I moved up here to the Pacific NW in 1995.
Got hooked up with some vintage racers, one of which I worked with and had a shop. He let me work on it at his shop.
My friend and I did a total strip down to bare metal (in 1999). It is a San Jose car and lived most of it's life in Cali. No rust. 289 2V, 4 speed car.
Applied a coat of DPLF epoxy primer, 3 coats of sandable primer, another coat of DPLF epoxy primer, a gallon of '98 Porsche ocean blue metallic. (Awesome color), and a gallon of DCU 2010 clear coat. (Did I mention the 100's of hours of body work?)
My friend who was letting me use his shop moved suddenly, I had to store it at someone else's house for 2 years, you get the picture. I finally bought a house of my own where I could work on it. YEAH.... It's taken a few years to get settled in, but now I'm finally working on it diligently.
Built the new 302 to BIG JOES specs from a magazine article:
ENGINE:
Block: '71 302 Mexican Block (beefy mains)
Pistons: Slight dish '71 302 - 0.030 over
Heads: C9TE 58cc milled to 55cc chambers. Minor port work, 1.94 - 1.60 valves
Cam: Isky 280 Mega - 232 @ 0.050 - .549 (1.7 ratio) - 108 LSA
Intake: Offy 360" Equa-Flow (Divided plenum, not ports) 1" 4 hole spacer
Carb: ProForm/Holley. 750 DP
Headers: 1-5/8" Long tube with 18" collectors
Ignition: Jacobs Pro Street digital with Ultra Coil. Crane street strip distributor.
CraneCams
TRANS: Jackson Racing C-4, GER 2800 stall convertor, B&M Megashifter
REAR: 8" with PowerTrax and 3.80 gears.
Also built it to road race with the following:
I have 620# front coils and 5 leaf reverse eye rears. I did the Shelby 1" upper control arm drop as well. Welded in a pair of custom made subframe connectors made of 1-1/2"x1-1/2" TS (tube steel, it's actually square). Matched the contours of the floorpans. If you weren't looking for them you wouldn't even notice them. In the last few weeks I welded in a full cage as well, so I probably could have forgone the connectors, but what the heck...
I welded in the Pro Motorsports Vario-Centric kit. I can't remember the instructions off the top of my head, but I think it gives you 8 camber settings in 0.5* increments. I'm shooting for 1.5 - 2* negative camber. Also installing Global West Adjustable strut rods, which will allow for the caster adjustment. (+3* sounds good)
I chose these two items to eliminate the need to use shims on the upper control arms at all. This also provides more precise settings.
1/8" toe in. I have seen some road racers go to 1/16" toe out, but you have to be careful. While it helps turning in, it can make the car wander at higher speeds on the straights.
When you take an early Mustang into an alignment shop, you'll see the veterans scurry away like roaches (because of the whole shim thing, get the camber right, go set the caster, re-check camber now it's off again, and the younger guys just tell you they don't know how to do it cause the computer doesn't go back that far)....
(VERY STIFF, perfect for high speed handling)
If I remember anything else I'll add it later. I will add more pics later as well.
12-14-2007, 06:04 PM   #10 (permalink)
mdnangl
Your going to love that Isky 280 Mega but Id put a Offy Port-o-sonic on her. I know its a single plane intake put it works really well with the 280..
BTW, the car is coming along nicely!!
Charlie
midnightangelracing.com
PS.. My friends and I have tried GER with very BAD results. Id Ebay that converter and go with TCI or the like!! my 2 cents
as the clock strikes midnight...
I didnt red light, the tree was slow!!!
mdnangl is offline   Reply With Quote
A new toy for the summer n2omike The Garage 12 05-08-2005 07:27 PM
Pushing the limits FoMoCo The Garage 2 05-09-2004 05:34 PM
Ford pushing a chevy vid FoMoCo The Garage 4 04-03-2004 02:02 PM
Summer is over..... Ponygirl67 The Garage 11 09-30-2003 10:56 PM
oil pushing out the dipstick! Luv70sFords All Ford Techboard 6 05-05-2002 09:06 PM
