01-25-2008, 01:00 PM   #11 (permalink)
blykins
Re: 445cid Windsor Stroker
Latest pic...
Got plug wires routed, dipstick installed, oil filter adapter & filter, and carb spacer. From the intake up is all temporary right now just to check fitment. I just tracked my pushrods and they were delivered today. So the plan for the evening is to pop the pushrods in, check clearance there, check for proper lifter preload, then run the valves. Tomorrow I'll pre-lube to make sure oil is getting everywhere it needs to be before I bolt the intake manifold on. Hopefully by this time tomorrow, it will be ready to go on the dyno. March 8th seems a long way off at this point.
blykins is offline   Reply With Quote
01-27-2008, 09:51 AM   #12 (permalink)
aaronford
WOW! That looks great. With 445ci and a hyd roller, it should be a torque monster. I agree that engines set to "KILL" typically do not make great street machines. Properly building an engine for the street takes a different line of thought. HotRod is getting better, but in the past, I have seen featured engines that would be a dog in the car yet produce wild results on the dyno. Huge Cam, huge carb, poor everything else. Interested in seeing your torque curve on the dyno.
Aaron
aaronford is offline   Reply With Quote
01-27-2008, 09:56 AM   #13 (permalink)
My427stang
I know Brent quite well talking to him over the years now and let me first say, this is a very well thought out high end street motor
However, dont mistake it for a truck motor just because its a hyd roller. 330+ cfm heads, a custom 250 @ .050 hyd roller cam with cutting edge ramp design and all the lastest tricks and goodies to make power. He didnt do a thing "off the shelf" on this one
This hyd cammed motor has more cam and more head flow than most of the hot rods around and most of all is very very well matched and big block displacement
I have a feeling this is going to be a very wicked, and drivable Windsor.
Moreover, if he makes too much more power than my 489 I am going to have to go back to the drawing board
Boy I hope it doesnt beat me up too bad LOL
70 Sportsroof, 427 FE/489 cid, 10.7:1,Ported Edelbrock heads, and RPM intake, 1000 Holley HP, Ceramic Hooker Supercomps, TKO-600, 3.70, A/C
01-27-2008, 01:14 PM   #14 (permalink)
blykins
You just made me cry Ross.
02-14-2008, 04:36 PM   #15 (permalink)
blykins
Well, only 23 more days till dyno time.
I gave myself plenty of time so that if any unexpected surprises popped up, I'd have time to maneuver.
Just so happens, I've had two.
1. My dyno guy didn't have any headers to fit TW-R heads. I was unable to locate any set of headers that would work, so I had to have a set of custom headers built. I wasn't too happy about that, but I didn't have any options.
2. I had rear main seal issues. I waited until the engine was finished and on the cradle to try and put the one-piece rear seal in. I had all kinds of issues. The seal wouldn't go. I tried all kinds of suggestions. I ended up having to drop the pan and drop the rear main cap. This really got my goat considering the engine was now on a cradle instead of the engine stand....plus it had 8 quarts of oil in it....plus I have a Moroso pan where the rear two bolts are IN THE PAN. There is no external flange at the back.
Anyway, I sucked it up and popped the seal in and changed that horrible orange oil pan gasket at the same time. It's back on the cradle and is awaiting dyno day.
02-14-2008, 05:05 PM   #16 (permalink)
Thordane65
Dude, that is one freakin sweet motor.
I think I need a little time to myself after seeing that
02-15-2008, 04:39 AM   #17 (permalink)
lees6t
Who makes those valve covers? They really look nice!
Lee
'60Falcon 302/AOD
"54 Ford sedan 351W/c4
lees6t is offline   Reply With Quote
02-15-2008, 06:08 AM   #18 (permalink)
blykins
Blue Thunder makes the valve covers.
02-15-2008, 06:13 AM   #19 (permalink)
n2omike
Looks awesome! However, you might need more than just the one breather and a pcv valve. Without enough ventilation, it might pressurize and leak oil out of that new rear main seal under load.
Personally, I would have at least an open breather on each side of the engine, and do away with the pcv valve.
Good Luck!
66 mustang
02-15-2008, 08:54 AM   #20 (permalink)
lees6t
Thanks for the info and good luck with the dyno
LEE
'60Falcon 302/AOD
452ci Windsor Stroker cognos Dyno Board 11 05-18-2007 05:00 AM
Windsor stroker..How hard is it? frdnut All Ford Techboard 22 11-05-2006 01:31 PM
Budget \"home stroker\" windsor 408 bigpres20012001 Stroker Engines 4 11-03-2006 09:27 AM
Biggest possible Windsor stroker? Turbo66HT All Ford Techboard 10 03-17-2006 08:35 PM
Windsor 393 Stroker Build-up aharmer Dyno Board 4 06-17-2005 06:51 PM
Powerhouse products
Probe Industries
