03-08-2008, 04:10 AM   #31 (permalink)
blykins
Re: 445cid Windsor Stroker
steharz, had to postpone until next weekend. Bad weather here. I'll keep you posted!
blykins is offline   Reply With Quote
03-15-2008, 06:41 PM   #32 (permalink)
blykins
Well, finally got it to the pump today. Everything went well, except for I had some intermittent distributor problems. I'm running a Mallory billet distributor and I think we were having problems with the module. I'm going to grab a new MSD then go back and hit her one more time.
Other than that, everything performed great...oil was clean, compression test was awesome, it's a good solid engine.
Peak hp was 586hp @6100, peak tq was 544 lb-ft.
I was shooting for 600, but with the ignition problems we were having, I couldn't get it to respond to a 1050cfm carb, timing, Super Sucker spacer, etc.
I know that 586hp isn't anything to sneeze at, especially for a street hydraulic roller cam and a 6100 peak, but it's got more in it.
I'm uploading videos to YouTube right now. I'll post them when I'm done.
03-15-2008, 07:18 PM   #33 (permalink)
blykins
Here's some videos...
This one is actually the very first breath it took....20 degrees initial time, full fuel bowls, fired on first crank.
03-15-2008, 07:26 PM   #34 (permalink)
frdnut
Wow that thing sounds great..I love the vid outside by the mufflers..
452ci Windsor Stroker cognos Dyno Board 11 05-18-2007 04:00 AM
Windsor stroker..How hard is it? frdnut All Ford Techboard 22 11-05-2006 12:31 PM
Budget \"home stroker\" windsor 408 bigpres20012001 Stroker Engines 4 11-03-2006 08:27 AM
Biggest possible Windsor stroker? Turbo66HT All Ford Techboard 10 03-17-2006 07:35 PM
Windsor 393 Stroker Build-up aharmer Dyno Board 4 06-17-2005 05:51 PM
