C4 to AOD
You'll want AT LEAST 3.55's...they came in Mustangs from '74-'78 and pintos/bobcats as well. Just have to scour the junkyards for 8" rear ends and look at the tag. Tag has the ratio on it. If you're lucky, you'll find a Mustang with a "3L55" on the tag...which designates a 3.55 ratio limited slip (posi). Grab it if you can...those are hard to come by.
There were also 3.80's, and aftermarket you can get 3.55, 4.11 (will also work with the overdrive) and 4.62. That's about it.
