04-30-2006, 07:26 PM   #1 (permalink)
jgnatek
suggestions for beefing up rear end
i have a galaxie 9" rear and a 289/cruisomatic going from galaxie into mav. obviously the 9" won't fit really, so im wondering what else would be burly.
jgnatek is offline   Reply With Quote
05-01-2006, 03:20 PM   #2 (permalink)
mavman
8" usually does great as long as you're not dumping the clutch at 7000 with slicks.
05-01-2006, 04:02 PM   #3 (permalink)
jgnatek
would i have to buy a whole rear axle or just a front loading 8" center? thanks
05-01-2006, 07:03 PM   #4 (permalink)
mavman
well if your Maverick already has an 8" rear, then any 8" center will fit.
But, if you have the smaller rear (was it a 7.5 or 6.75?? Cant remember) than you would be better off finding a 8" out of a Maverick or Comet. Bolts right in and they can be had super cheap.
05-06-2006, 12:28 AM   #5 (permalink)
dacofa
8" rearends are allot stronger then they're given credit for. More parts are becoming available along with alum 3rd members. It's lighter then a 9" and when you lift the 3rd member you'll feel the difference. Gear selection is biggest drawback. But on the other side of the coin, it's not as confusing either. 3.00, 3.25, 3.55. 3.70s and 4.11 pretty much covers what you should need. My son's 72 Mav Grabber, I used an 8" with 4.11s and an AOD. Best of both worlds, IMO.
10-16-2006, 06:32 PM   #6 (permalink)
347Maverick
i put a 9 inch from a 57 Ranchero in my maverick, the best thing is that as long as the measurments are the same it's an easy swapt to put over. the trick is finding the rearend that fits and is the same width. with mine it went from the stock 8 open diff with 3.4's to a 3.89 spool in the 9 inch
347Maverick is offline   Reply With Quote
12-13-2006, 03:12 PM   #7 (permalink)
1fstpny
we installed a 355 and a posi-unit, in the boys 8" and its holding up fine!:&gt[img]/forums/images/smiles/icon_wink.gif[/img] 8" are suppose to be good to over 500 rwhp. Mac
