04-04-2007, 06:07 PM   #11 (permalink)
outsider75
well got my maverick!
my brother has been using a set of headmans for a 351 in a 66 mustang in his 73 maverick.
outsider75 is offline   Reply With Quote
04-04-2007, 06:10 PM   #12 (permalink)
428cjmaverick
really,how well did they fit and what work if any did he do to the shock towers?
428cjmaverick is offline   Reply With Quote
04-21-2007, 04:45 PM   #13 (permalink)
ratio411
The Tubulars and Hedmans are 1.5" primary tubes.
That is a bit small for a 351, and downright tiny for a 408!
Crites Restorations makes a 1.75" header that would be much more fitting for the cubic inches.
Hooker also makes a big tube header for Windsors in a 65-66 Stang that can be fitted to a Maverick with a little tweaking. Part number 6208.
ratio411 is offline   Reply With Quote
04-21-2007, 04:49 PM   #14 (permalink)
ratio411
BTW: Was your car originally a v8 car?
If so, all of the mounting stuff and tranny will work fine.
A car front sump pan for a W is all you need for the engine itself.
The mounts, pulleys, tranny parts, accessories, etc... for a 302 will swap right to a 351w. They will swap to a Cleveland too, for that matter. I did the Cleveland swap on my 75. Used Tubular headers for that, however, they are big tubes for the Cleveland. It's exhaust ports don't exit into the shock towers, so the swap is a little easier and the tubes can be much bigger. Just don't plan on changing the plugs unless you shave the towers.
04-21-2007, 06:11 PM   #15 (permalink)
428cjmaverick
it was a i6,but had a 302 swapped in then i got it with no motor or trans,
we do plan on shaving the shock towers as much as needed.
08-23-2008, 01:00 PM   #16 (permalink)
shadow15
Re: well got my maverick!
dude i just got me an old 1975 maverick it was my friends i payed him 45 its a junk car and yes im only 15 years old but im making it into a racecar so wat am il look in at, hes got everthing excecpt the aftermarket parts i got to buy them so yea
shadow15 is offline   Reply With Quote
Holley
Probe Industries
