12-22-2006, 08:34 PM   #1 (permalink)
LittleFranky
Compression Pressure Test
Does anyone know if I can do one of these without having the engine in the car?
LittleFranky is offline   Reply With Quote
12-25-2006, 06:46 PM   #2 (permalink)
LittleFranky
Thanks Guys. I did it today on a 1973 302ci and here are the readings I got:
1-170psi
2-160psi
3-160psi
4-160psi
5-170psi
6-165psi
7-165psi
8-160psi
Is that engine good to go?
05-08-2007, 10:36 PM   #3 (permalink)
PaulS1950
The compression is high enough - and then some.
Was the engine warm? was the throttle held open?
Was there oil in the cylinders?
The compression looks to be 8.5 or 9 to 1 - that would be close for a stock 73 302 with low miles.
Paul
05-09-2007, 05:20 AM   #4 (permalink)
mavman
And how do you determine the static compression ratio based on cranking pressure?
05-09-2007, 03:21 PM   #5 (permalink)
mstngjoe
X2!
08-06-2007, 06:06 PM   #6 (permalink)
FoMoCo
Re: Compression Pressure Test
You don't
08-06-2007, 09:22 PM   #7 (permalink)
mustang42782
that engine has a good spread! (let the jokes begin) I say good to go !
Lakewood
