Re: I need a carburetor recommendation?
James,
The 289 and 302 run good on a 600 CFM vacuum secondary carb as long as you are not turning over 6000 rpm. Above 6000 you may get better top end from a 720 CFM vacuum secondary carb. Unless this is a race only vehicle you are not going to need a double pumper.
Paul
