10-08-2009, 01:15 AM   #1 (permalink)
Rudzek
Exclamation Transmission Help!!!
Hey, i'm new to the whole fixing cars deal and i'm trying to teach myself. so far i dont know very much but i basically have the gist of things...
my transmission is dead. i'm going to take it out and put a new one in. i have a '75 ford maverick. my question(s), how do i turn my automatic 3spd transmission into a manual. i would rather do that now, seeing as though my tranny's dead, instead of fixing the tranny and getting it converted to a manual later. does anyone have any diagrams or instructions on how to do such a thing? What type of transmission am i going to need?
all the help i can get would be sweet.
thanks-
-Robb
Rudzek is offline   Reply With Quote
10-08-2009, 07:49 AM   #2 (permalink)
Re: Transmission Help!!!
ABRACADABRA, has always been a favorite for me...
Seriously though you will need several things you currently do not have on your car.
1: A Manual Tranny
2: A Maverick Clutch Quadrant and pedal and linkage etc...
3: Manual Transmission crossmember
4: Flywheel
5: Clutch Set
6: Pilot Shaft Bearing
7: Clutch return spring
8: Manual Transmission Shifter (for what ever style tranny you pick, the shifter must match, and there are a lot of them...)
9: Manual tranny shift Linkage
10: Gotta remove the front seats and carpet
11: Cut hole in floor for linkage...
The list goes on and on and you will need in excess of $1,000 bucks to do all this... Unless you find a donor car to get the majority of your parts off of.
The tranny will cost you $500 to $1,000 depending on what you want....
Good Luck!
FE
Honor!
10-08-2009, 04:00 PM   #3 (permalink)
TrikeKid
What engine? With the 302 I know you have a few options ranging from 3-6 speeds that will physically bolt behind it. I'm not up on what you can do behind a sixer.
What I would do is swap in a T-5 out of a Mustang. They're strong, have overdrive and plentiful. And the pre-fabbed crossmember is coming very soon from a member of the maverick forum at mmb.maverick.to.
The clutch pedal and linkages for Mavericks are getting very hard to find outside of a car and there is a big demand for them so you might end up paying a chunk of change for it.
TrikeKid is offline   Reply With Quote
10-08-2009, 04:03 PM   #4 (permalink)
I wouldn't bother answering any more, I think he was spam.......
Honor!
10-10-2009, 01:31 AM   #5 (permalink)
Rudzek
Hey guys. thanks for the help. i'm not sure if i actually understood half of what you said seeing as though i'm still a little new to this. but the list is really helping. i have a 302 v6... from what i've heard from other people, i can basically get a four speed and thats about it?
there's a couple used maverick ads up around my area selling for parts so that'll be good but then again, i dont think i remember any of them being manuals... but there's a mustang junkyard/car lot down in albany, and if i assume correctly, most mustang stuff can be swapped? but idk which things can and cannot.
again. thanks for the list. and sorry for the long wait for a reply... no i'm not spam.
10-10-2009, 09:28 AM   #6 (permalink)
PaulS1950
Rudzek,
Mavericks never came with 4 speeds - that is a swap that some do for performance. Factory cars came with 3 speed manual and automatic transmissions. The automatic - C4 - is the stronger of the two but you need to keep them cool and improve the shifting so they shift faster. I believe you will find that it is cheaper to have the C4 rebuilt than it will be to put a manual in the car. If you just need a manual for fun then go for it - you will learn a lot in the process.
Paul's Street and Strip
Performance AODs & C4s
paulstephens@q.com
6522 51 Ave. S.
Seattle, WA. 98118
206.725.0881
10-10-2009, 09:59 AM   #7 (permalink)
Rudy... You gotta BOOK UP man.
Go buy a Motors or a Chilton Manual.
Better yet, go to the Library and read in a Haynes or a Chilton about Ford Motors before going any further.
You need a LOT of basic tutoring about Fords before going any further.
Plus you will need about $2,000 to start and finish this job, and that's doing it the cheap way.
Ford never made a V6 in 302 cubic inches.
You CAN put a 2 speed auto, a 3 speed auto even an AOD 4 speed auto behind your 302.
You CAN put a 3 speed standard, a 4 speed standard and a 5 speed standard in that Maverick. But doing any of the above is going to take a LOT of attention on your behalf, unless you wanna let someone else do it for you. Then all you need is money. Likely a LOT more than $2K...
So start reading, and come up with a game plan. You got 32,742 members here that have experience in one or more things automotively related to Fords, and of them there are 2,683 Active Members that participate on a normal basis.
This forum is the premier place on the WWW to get info on your Ford and how to modify it.
Get ready and let's do this! (get a camera)
FE
Honor!
need a t-5 transmission MustangRanger Wanted 1 07-24-2008 08:39 AM
C4 transmission? DAVIDE C4 Transmissions 4 01-19-2008 08:27 AM
t 5 transmission ? stillinmo Falcon Pages 1 01-17-2008 06:30 AM
C4 Transmission ??? 70sportsroof All Ford Techboard 3 11-11-2003 09:02 PM
Transmission help, anyone? 69convert All Ford Techboard 17 11-10-2003 10:01 PM
Probe Industries
