24 inch radiator installation - lower bracket help
Tim; The picture is very close I can't get an understanding of where the brackets are attached. Looking at the brackets from NPD, the straddle "U" bracket with the three holes that locate the rubber piece is on the same angle as the frame rail support. If these brackets were mounted on the inside or ouside of the frame rail support, the staddle U bracket would be inline with the lower radiator tank. Can you give me an explanation of where to mount these brackets or a picture that is further away? I really appreciate your help. You 69 looks great, how do you like the FPA headers?
