carpet install
Fuzzy side up, hmmmm....that sounds crazy enough that it just might work!![img]/phpBB/images/smiles/icon_lol.gif[/img]
I am sure it's not too different from when I put carpeting into my 71 Fastback, like it was said, leave it in the sun to loosen it up some, new carpet can be a real pain to install when it's stiff.
Things to consider is to make sure all seats are out (I know that one sounds obvious...but I have a friend who was determine to try and do it with out removing them[img]/phpBB/images/smiles/icon_frown.gif[/img]), remove kick panels and door sills, and it's a great time to vacuum out the interior.
Start with the back, the front piece will lay over it when you get to it. Then just try and fit it in the best you can, most carpets have a slight contour in them that follows the floor pans, so it's not bad to do at all.
Then comes the fun! I have an automatic, so I remove the shift handle and "feel around" for the hole, then cut it out. For all the other holes I use a scratch awl, or an ice pick...poke around in the area you suspect it's in, you'll find it.
Some people I know will use a drill to go through the carpet with a bit, but that snags too many threads out of it. What I did was to get a metal tube that is sturdy and make sure it's just under the hole size, and punch through it. Worked pretty well for me!
Good luck!!
<font size=-1>[ This Message was edited by: Humphrey351 on 7/27/05 12:52pm ]</font>
