8/24/05
I got out there at 10:00 am and Got started.
First off I Vacuumed it all down
Then I wiped it all down with Wax And Grease Remover
Then I sealed all the seams With Fusor800 urethane sealer working front to back this took about 4 hours
Then I Vacuumed it all down again to get all the dirt my shoes drug in when I was sealing
And wiped it all down with Wax And Grease Remover Again
Then I drug all my painting equipment out , paint gun, mixing cups, strainers, Fresh air respirator, air lines, Fans, Etc.
Then I got my tack rag and tacked right before I sprayed “Tack a panel then spray and move on to the next panel”
I sprayed the firewall, and the rear seat, and the ceiling, Making sure not to trap myself “Remember you have to at least put 2 coats on so you cant get back in the car if you do the floors” let flash and sprayed those three areas again and then again.
Then I did the trunk Let flash and sprayed it again, flashed then again.
Then I did the speaker part, All the sides, flashed then sprayed again
Then I sprayed the floors Flashed sprayed, then again
All this took 8 Hours 24 minutes
Here is the before pictures After sealing
After spraying
The pictures don’t do it any justice at all
Richard
