10-17-2005, 04:14 PM   #1 (permalink)
smuttysmith385
i need a picture of......
the underside of a 67 mustang behind the right hand front tire, around the frame rail and rocker panel. I need an idea of what is there. I brought home a 67 coupe this weekend and I think the jackass that had the car before me cut some stuff out...that he shouldent have[img]/phpBB/images/smiles/icon_bicker.gif[/img]
Can someone help me out, I am new to Mustangs.
smuttysmith385 is offline   Reply With Quote
10-18-2005, 07:07 AM   #2 (permalink)
beegshot
IIRC, on the 67's there was only one torque box. I believe it was on the drivers side. So if one side looks different than the other...that's the reason. Again IIRC, in 68 they started putting torque boxes on both sides.
Robert
Beegshot
65 1/2 'stang, Hard Way
79 F100 SuperCab, parts hauler
03 Expedition, grocery getter, kid hauler
Henry Ford said, "If you find you need a tool, you have already paid for it."
<font size=-1>[ This Message was edited by: beegshot on 10/18/05 6:07pm ]</font>
10-18-2005, 09:40 AM   #3 (permalink)
CaptVirgilHilts
[quote]
Robert
You are correct no RS torque box till '68. I added a passenger side torque box on my '67, mainly because The car was starting to sag on that side. Stu
10-18-2005, 09:07 PM   #4 (permalink)
smuttysmith385
well i guess he wasn't a jackass after all[img]/phpBB/images/smiles/icon_redface.gif[/img]
12-06-2005, 04:58 PM   #5 (permalink)
351stanger
was the right side torque box an easy install? well as easy as replacing the drivers side would be?
thanks,
carl
351stanger is offline   Reply With Quote
12-07-2005, 06:30 AM   #6 (permalink)
beegshot
I just added torque boxes to my 65. It was a piece of cake...except the torque boxes were made for a convertible. FWIW, the convertible has a different inner rocker panel. So, the torque boxes needed to be modified slightly. If you can find some that are made for a coupe, you're golden. As I said, they're not hard to install. On a scale from 1 to 5 (with 5 being most difficult), it's a 2 or 3.
Robert
12-07-2005, 08:19 AM   #7 (permalink)
351stanger
thanks i just ordered about 700$ worth of parts. this winter im replacing most of the front 1/2 of the car, new drivers side frame, pass. shock tower, cowl, floor pan and supports, it came with 2 torque boxes for the frotn also. so that will keep me busy for a while. other than subframe connectors and an 8 pt. roll cage is there anything else i should do to strengthen the chassis?
thanks,
carl
