C4 Transmission
Hi,
Are you converting from a manual trans if so, did you remove the pilot bearing, another thing is have you tried the torque converter by itself into the crankshaft bore, some times they are burred up and also put a little never sieze or equivalent on the nose of the converter, it will help it slide into the cranshaft bore.
Fred
