Whats needed to switch 69 Mach 1 to power brakes?
You'll need the booster/master cylinder, prop valve, disc are different, brake pedal, different ratio then manual drums, spindles, dust plate, calibers, new brake hoses, rotors, wheel bearings and seals. Best if you can find a 68-73 Stang, 68-73 Cougar, 68-71 Fairlane/Torino. Probably a few I forgot. The Granada/Monarch, Comet/Maverick will also work but the spindles, calibers, rotors are different. But they'll work. You might have to change a few brake lines.
