cooling temp.
just completed a 351w bored 40 over, stroke is stock (3.5), mild cam .456 lift on both intake and exhaust, wiend stealth dual plane intake with holly750 (probably to much carb.), aluminum brodix heads with 2.02 and 1.60 valves topped with comp cams roller rockers 1.6 ratio, this is accompanied with a griffin aluminum radiator . thermostat is 160 degree. msd electronic ignition.
have not even broke in engine, but it seems to be running a little warm 190-200 is this normal? should i change thermostat?
