12-27-2005, 10:54 PM   #1 (permalink)
tkj
disk brake conversion
Iput spindles and disk brakes off a 75 maverick on my 68 6-cyl . Can I still use my non power master cylinder? I also swaped the rear end , the mouting points are the same but the over all width is 2 inches wider. Will this cause a problem?
tkj is offline   Reply With Quote
12-29-2005, 08:28 PM   #2 (permalink)
dacofa
2" won't be to bad. Check the tire to fender for rubbing. If you're buying new rims you can go with 1/2"-1" more negative offset to bring the tires back under the fenderwells. But check now much clearence you have to your leaf springs first. 75 Mav spindles use a different outer tierod. I think Mustang Unlimited has them for $30 each. Brake hose are different. Master cylinder, if you had drums before you might have to step up to a larger piston. Calibers require more volume then drum brakes. Get the prop valve to. Test drive the car in a VERY safe place with no other cars around. Big parking lot at night is best.
02-09-2006, 01:31 PM   #3 (permalink)
fnracing
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>Master cylinder, if you had drums before you might have to step up to a larger piston. Calibers require more volume then drum brakes. Get the prop valve to. Test drive the car in a VERY safe place with no other cars around. Big parking lot at night is best.</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE> You WILL have to change the MC. I used a MANUAL DISC BRAKE MC from a 1974 Maverick for my '69 and it fit right in. Believe it's the only MANUAL MC for disc brakes that Ford made back then. Your '68 might require a different pedal but they are available all over for a few bucks.
Good luck.
fnracing is offline   Reply With Quote
