65 headliner kit
Not too bad a job.
Get it as tight as you can when you install and dont bend the wire loops.
Once you have it in you can take a hair dryer or heatgun and shrink out what wrinkles you may have left.
But it only shrinks a little so get it as tight as you can when you install.
Be carefull if you use a heat gun and only use the low setting.
Front and rear windshield out helps a bunch but not required.
Expect to spend the day doing it.
Good tunes and a helping hand too.
