03-24-2006, 06:34 AM   #1 (permalink)
engelhornc
\"set\" screws inside intake side of screw-in rocker studs? (newbie)
I have 78 heads (yeah, not the best) going onto my 302. In the process of screwing in the rocker studs, I see that the intake side studs hit an allen screw before they bottom out. The "nut" portion of the stud is staying proud about .1".
Any problem with this? I don't relish the thought of trying to remove those set screws.
engelhornc is offline   Reply With Quote
03-24-2006, 09:00 AM   #2 (permalink)
ckelly
I would not run it like that. Were these heads cut for screw in studs? And the allen head screws the big ones? If so - the studs should be nowhere near the big screws.
03-24-2006, 02:36 PM   #3 (permalink)
engelhornc
They're factory threaded, and the screws I'm talking about are only in the intake rocker stud side, not any in the exhaust
side.
So you say pull 'em, eh?
03-24-2006, 03:03 PM   #4 (permalink)
dfree383
????? Post a picture, Please ????
03-24-2006, 07:20 PM   #5 (permalink)
engelhornc
Here's a couple pix
<font size=-1>[ This Message was edited by: engelhornc on 3/25/06 9:11pm ]</font>
03-24-2006, 07:22 PM   #6 (permalink)
engelhornc
Ooops... Fatfinger, sorry...
<font size=-1>[ This Message was edited by: engelhornc on 3/25/06 9:09pm ]</font>
<font size=-1>[ This Message was edited by: engelhornc on 3/25/06 9:10pm ]</font>
03-27-2006, 11:58 AM   #7 (permalink)
thekingofazle
Sure your stud's not just too long and thats a blind hole?
03-27-2006, 02:08 PM   #8 (permalink)
ckelly
I don't believe that a 78 302 head was ever threaded from the factory. I might be wrong, but that is a performance mod and not done since the HP 289. What's missing is the guide plates. The stock non-adjustable pedestals should have been cut down about .3 to allow for the stud and plate, then tapped as needed. Late model heads may be tapped but they are for bolt down rockers too.
03-28-2006, 01:30 PM   #9 (permalink)
thekingofazle
That sounds right, and makes perfect sense.
