Throw out bearing clearance issue with Lakewood Bellhousing
The long finger pressure plate sits higher off the flywheel than the diaphram type. You can adjust the cable back if you have an adjustable one. If it isn't adjustable, the other option is use a diaphram type pressure plate, or both.
