Master cylinder with Disc/Disc brakes
I'm sorry not everyone is such a know it all like "retroo", the world needs big "I ams" to tell you you're doing something wrong. I mentioned something that worked, not whether it was right or wrong. Plus, it was done at a time when there weren't many affordable aftermarket choices available. You have to read the statement completely, process the information in your brain and then engage your mouth and opinions, otherwise you may look like a donkey blowing your horn. I would not modify a mastercylinder today with the available choices. But like I said, I was given good instructions, I follwed them precisely and like in true hot rod fasion, it worked and worked well. Certain procedures may require a technique not everyone posesses. And it is an advantage if there are step by step instructions to follow, hopefully written by a competent person who has done the task. This is not for everyone.
When you know the amounts of how much fluid is displaced by a calipers' piston area due to its displacement and the distance it travels in its bore multiplied by the number of pistons in that caliper vs the volume of the wheel cylinders' opposing pistons and their distance of travel pushing out brake shoes, professor, let me know I can learn more from you.
<font size=-1>[ This Message was edited by: Farlainer on 6/29/06 12:35am ]</font>
