05-31-2006, 07:40 PM   #1 (permalink)
pass1over
Pitman Arm
Is a pitman arm keyed so it only goes onto the steering shaft in 1 position, or do I have to find relative center of steering range and then put it on?
I have normal clearance between inner tie rod on passenger side and idler arm, but super super close tie rod/pitman arm on drivers side. Ive chcked the tie rods, ordered 2 from 2 diff places, its not them.
The center link is my next choice of things to check out. I have a new one, but they look almost identical.
Car has 1" lowering springs and the shelby mod done. Would these mods require me to get or not get a certain type of pitman arm? I might have the "quick ratio" pitman arm on the car, which I understand is a bit longer. Maybe I need to go back to the stock unit?
The pitman arm is near 1 side of the bend on the inner TR, but ont eh other side its right int he middle of the bend where it should be. It looks like the bend or pitman arm/center link connection point is in the wrong place.
_________________________________
slammed '04 RX-8 (daily driver)
stroked '66 Mustang (weekend fun)
<font size=-1>[ This Message was edited by: pass1over on 6/1/06 10:51am ]</font>
<font size=-1>[ This Message was edited by: pass1over on 6/1/06 10:56am ]</font>
pass1over is offline   Reply With Quote
05-31-2006, 09:50 PM   #2 (permalink)
dacofa
Pitman Arm
It's keyed but not with a keyway. It has a tooth left out of the splines so it only goes on one way.
05-31-2006, 10:32 PM   #3 (permalink)
FALCONAROUND
Pitman Arm
I have seen them installed where they were off because some idiot had hammered it on then slapped it tight with an impact after hammering it on.... The keway like said above is a double flat tooth...
FE
When my Gecko is broken, does that mean I have 'A REPTILE' Dysfunction?
06-01-2006, 06:47 AM   #4 (permalink)
pass1over
Pitman Arm
ok, so i dont think its the pitman arm then.
Has anyone else with a 65/66 that has done shelby mod and has 1" drop springs in front experienced any clearance issues witht heir s uspension parts? or am i the only one?
'08 Infiniti G37S daily driver
stroked EFI '66 Mustang weekend fun
06-02-2006, 05:36 AM   #5 (permalink)
dacofa
Pitman Arm
There actually was a difference pitman arm on the early Shelby Stangs.
06-02-2006, 08:18 AM   #6 (permalink)
FALCONAROUND
Pitman Arm
WAIT!!!!! The '66 I did in England a few years ago had the keyways yes, BUT! They were a tri keyway and you could install it into any of 3 positions.... Each position divided a circle by 1/3rd. Your's probably is NOT put on incorrectly because in the other 2 positions it is IMpossible to hook up the steering linkage...
FE
06-02-2006, 08:47 AM   #7 (permalink)
pass1over
Pitman Arm
Thankyou for all the info and help guys. Turned out it was the center link. Replaced it and all is gtg now.Woot!!!!!
Now its on to the next problem that arose - overheating.
Sigh, damn old cars, its always something.
<font size=-1>[ This Message was edited by: pass1over on 6/3/06 2:48am ]</font>
