07-10-2006, 04:35 PM   #1 (permalink)
427sidewinder
71-73 Trunk mount battery location ?
Hey guys movin the Batt to the trunk. Got the Summit relocation kit. Ive read your suppose to run the battery plates parallel to the body if I run it this way it runs against the body instead of long way w/ the body . My ? is for those who have done this on 71-73 bodies did you mount it in front of the tank towards the rear seat or farther back. theres not a whole lot of room if I go in front of the tank to work on the top side of it. & the frame rail runs pretty close[img]/forums/images/smiles/icon_confused.gif[/img] Any boby got any pics ??
<font size=-1>[ This Message was edited by: 427sidewinder on 7/11/06 6:35am ]</font>
427sidewinder is offline   Reply With Quote
07-12-2006, 12:42 PM   #2 (permalink)
dacofa
Pass in the area just behind the tire. And mount it the direction you said with the plates facing to the side. Might want to look into a shutoff switch too.
07-13-2006, 07:24 PM   #3 (permalink)
427sidewinder
Thanks for the info, Got it in! Ended up like 9" from the Taillight panel on pass side behind rear tire. J-bolts kinda close between the frame &amp; tank.
Used 2 Ga. all throughout, Also on engine to frame for ground
[img]/forums/images/smiles/icon_tup.gif[/img]
