belt position
I just put a new 302 in my 1970 mustang. The motor I took out had a single groove pulley on the water pump, and a 3 groove pulley on the bottom (crankshaft) pulley, the car has air conditioning. The motor I just installed came from a car that didn't have air conditioning, so the water pump pulley had 2 grooves, and so did the bottom pulley. I don't know which set to use, because I don't know the proper belt alignment. I've seen a picture of a 1970, it had a water pump single groove pulley, that had the belt going to the power steering. The second groove on the bottom pueely went to the alternator, and the third to the air conditioner. Someone please advise me on the proper alignment of the belts, and which set of pulleys should I use? Thanks
