Early smog questions
The factory shop manuals will tell you the prefix, suffix or some abbreviation as to what distributor was intended to be used with the engine/trans combo. However, if there were problems with the auto in the early 1980's, that distributor may have been yanked out, and some smog OK one screwed in. It gives poorer gas mileage and performance but is legal. In the late 1970's California also required a retro-fit box be installed before testing and approval on all engines, and in many instances they required a Dist. replacement, for there were only certain tested and legal numbers in the Sacramento computer. In the late 1990's this progam got obsoleted, and it was OK then to use original equipment, except for when the title was transfered. There were just too few of the older vehicles then on the road, and one certain old car engine combo took up as much space as a newer more popular vehicle.
I found diagrams for complete Ford line circa 1970 at a swap meet for $1. None of which match my vehicles, and I did not fiddle with anything under the hood either. Apparently they were printed up in 1969, thought to be OK for 1970, but not really approved or used. There was a supplement issued to dealers in the Shop Talk magazine which contradicted the $1 diagrams.
Wm.
Wm.
