Transmission rebuild ...
Well I'm about to give up. Since my last post I've had the trans out three times to replace the front seal and the pump bolts were not tight. The next time again I replaced the seal and all of the bolts could be removed without a wrench, not even finger tight. Well guess what. Its leaking again from the bellhousing, but we're getting real good at it taking it out. (out and back in less than fours. The last time it was out I used thread lock. Could there be cracks in the trans tapped holes? I can torque to specs (20ft. lbs.) without any problem, so what gives? I'm about to purchase a reman and give up on this one. I'm only out the cost of a rebuild kit and several weekends. It will last about a week or so before it gives out. My son (the daily driver of the stang) thinks the engine is too much for the trans. (wants a C6) How much trouble is that to install instead of the C4? (289 engine). Also the trans will shift up ok, but tends to shift down real hard and will shift out of 3rd to 2nd slowing down at around 30 mph. What's causing the hard shift down? Where (who?) has the best deals on transmissions?
<font size=-1>[ This Message was edited by: my67mustake on 10/21/06 9:53am ]</font>
