10-21-2006, 03:13 PM   #1 (permalink)
67mustangcoupe289
C4 to C6 Transmission Swap
i have a 67 mustang with a 289 under the hood. my C4 transmission is crap and tends to leak about a week after we pull it out. its leaking from the bellhousing and where the bellhousing meets the transmission body itself. we have took it out and put it back in 4 times. so now im thinking about scrapping the C4 and put in C6 tranny in. my question to you is will everything bolt up correctly? will the drveshaft work? linkage and trans cooling lines be correct for the C6? there is a TCI "sizzler" C6 transmission from summit racing that is for the small block ford. this is the trans im looking into getting. i just need to know if everything will "bolt" right up and not have to modify anything.
thanks
mike
67mustangcoupe289 is offline   Reply With Quote
10-21-2006, 04:43 PM   #2 (permalink)
plumber68
i would just get another c4 they a great light strong little tranny's the c6 weightsmore and also uses alot more power to the rear wheels, that means your car will be slower
plumber68 is offline   Reply With Quote
10-21-2006, 04:43 PM   #3 (permalink)
plumber68
10-21-2006, 04:54 PM   #4 (permalink)
67mustangcoupe289
yeah but my question is will a C6 bolt up with the original linkage, driveshaft, cooling lines without having to change anything?
10-21-2006, 07:12 PM   #5 (permalink)
64 TBOLT
the C6 is longer
