66\' Mustang carpet \"80/20 loop\" or \"nylon loop\"???
Well, I used to work in a vintage mustang shop for over 20 years . The 80/20 used to be the better quality carpet to hold up over the long run. Then around y2k the EPA came down on the type of chemicals used by the manufacturers to dye the carpet. From our experience, the 100% nylon held the dye better than the 80/20. It is a bit softer though. We only sold the best carpet out there, and for a while, if you'd spill even water on the 80/20, when you wiped it down, it would release the dye from the carpet and you'd have a lighter colored area. Haven't been there in 2-3 years and I hope that the quality has gotten better.
Summary: 80/20 more durable and firmer, but 100% will hold the color better if you're going to be spilling a lot!!
If anyone else has some info, I'd like to hear it as well. Hoped this helped.
