01-22-2007, 01:00 PM   #1 (permalink)
smetskurt
How to clean the engine inside?
Hello, I am rebuilding my engine from my mustang. At the inside of the engine, behind the freeze plugs on the block and inside the cilinder heads there is a lot of rusty dryed cooling water and stuff on the iron. How is the best way to clean my engine? Can I do this on my own or do I better take the parts to a machine shop? Is there a specific way engine builders clean this in America? I live in Belgium, and here aren't a lot off specialized engine builders of old cars. Greetz, Kurt.
smetskurt is offline   Reply With Quote
01-22-2007, 01:10 PM   #2 (permalink)
Take it to a machine shop and have them put it in a Parts Washer machine. It is a VERY large Machine with high pressure jets shooting heated water with a special cleaning agent that get's the block very clean. This will remove most of the junk from your engine.
If you are on a budget, use a product called LIME AWAY, or Rust and Lime Remover, spray it or pour it into the block and let it sit a while then wash it out with a garden hose and a spray nozzle.
I recommend you remove all the block plugs before rinsing.
FE
01-22-2007, 02:11 PM   #3 (permalink)
MJMcCarthy4
I'll agree with what FE said, but even on the cheap you can take it down to a self-service car wash and take advantage of a high pressure spray instead of relying on a garden hose.
MJMcCarthy4 is offline   Reply With Quote
01-22-2007, 02:44 PM   #4 (permalink)
Do they have car washes in Belgium? Or just just Chocolate Factories... LOL [img]/forums/images/smiles/icon_wink.gif[/img]
I'm so depressed... My doctor refused to write me a prescription for Viagra. He said it would be like putting a new flagpole on a condemned building...
<font size=-1>[ This Message was edited by: FEandGoingBroke on 1/23/07 4:44am ]</font>
01-24-2007, 10:02 AM   #5 (permalink)
thekingofazle
Yep - machine shops around the world put the block either in a "hot tank" where the block is put in a bath of caustic soda, or in a spray booth, where a bunch of jets of the same liquid are sprayed at the block. Either way, it removes rust, scale, just about anything. Any machine shop that rebuilds iron block engines should be able to help you out, no matter what the brand.
Be sure that you put oil in the cylinders after you get it back, as the iron will start rusting immediately.
02-01-2007, 03:14 PM   #6 (permalink)
smetskurt
02-01-2007, 03:17 PM   #7 (permalink)
smetskurt
Thanks, I found a big machine shop. I think I will take it to those guys. They seem to have all the equipment and their price was good. I will also look for another one and compare them. Thanks for the information. See you later.
