68 5.0 swap pulley question?
Currently on my 5.0 swap, the only pullies I will be using is the crank, alternator, and water pump. Should I also buy the smog pump and A/C delete pullies and use the stock belt? or is there a way to bypass all of that and use a shorter belt. If so what is reccomended? Also should I use stock pullies or underdrive? I am thinking with no A/C, no power steering, and no smog there is no use for the under drive pullies, but then again I am learning as I go.
