05-01-2007, 01:55 PM   #1 (permalink)
SCHOONER
ORIGINAL SIZE OF THE FUEL LINE ? ? ?
Hi
I own a '66 convert. and want to upgrade my fuel to the next bigger size.
QUESTIONS PLEASE:
1. What in the world is the original fuel line size?
(I looked in my shop manual and I just can't find it . . . help)
2. What would me the next fuel line size up, that I can install?
Thank you guys for all your help in the past with this newie, and hopefull in the future too.
GOD BLESS YOU ALL
Schooner [img]/forums/images/smiles/icon_cool.gif[/img]
SCHOONER is offline   Reply With Quote
05-01-2007, 02:07 PM   #2 (permalink)
cccdjb
Pretty sure stock is 5/16" as that is what I have in mine. The next step up would be 3/8". Which I'll be upgrading to soon. 3/8" from tank to pump and -6 AN (3/8") from pump to carb.
cccdjb is offline   Reply With Quote
05-01-2007, 03:37 PM   #3 (permalink)
pass1over
cccdjb is correct. 5/16" is stock, next up would be 3/8 or -6AN
I just did half this swap on my '66
pass1over is offline   Reply With Quote
05-01-2007, 08:15 PM   #4 (permalink)
coosbaylumber
Really, about the only reason to go to a larger diameter fuel line is because your big engine is sucking in so much of the valuable fluid. There are a lot of 300-400 H.P. engines out there doing just fine with a 5/16ths line. Think of H.P. and fuel line diameter in same frame of mind.
Wm.
05-01-2007, 08:28 PM   #5 (permalink)
SCHOONER
Wm.
Hey Coosbaylumber
My engine is being rebuilt very slowly unfortunatly. However, being a newie at all of this great rebuilding stuff.
QUESTIONS PLEASE:
Is a know fact that I better off not upgrading my fuel line to:
3/8's ?????
Also, would you recomm. me putting an electric fuel pump at the back of my fuel line near the tank ?
Thanks guy
GOD BLESS
05-02-2007, 01:05 AM   #6 (permalink)
dacofa
If running a mech pump and it works fine, stay with it. If you go to the bigger fuel line also get a new pickup due to age.
05-02-2007, 04:33 AM   #7 (permalink)
jonnys
As stated above if you up grade your fuel line as stated standard is 5/16 you also need to upgrade the pick up as this will still be 5/16. A lot of people forget about this.
jonnys is offline   Reply With Quote
05-02-2007, 06:23 AM   #8 (permalink)
beegshot
I believe the 67 pick-up is 3/8". There's an article here about modifying the pick-up.
Here's the link:
http://www.fordmuscle.com/archives/2...Line/index.php
Robert
Beegshot
65 1/2 'stang, Hard Way
79 F100 SuperCab, parts hauler
03 Expedition, grocery getter, kid hauler
Henry Ford said, "If you find you need a tool, you have already paid for it."
<font size=-1>[ This Message was edited by: beegshot on 5/2/07 8:27pm ]</font>
05-02-2007, 07:15 PM   #9 (permalink)
coosbaylumber
If you install a standard electric fuel pump near to tank, it will easily push the required fuel forward. Was standard practice for customers complaining of vapor lock in the Palm Springs area.
Just installing the second pump will increase the GPM about by 1/2 over present. But,.... if feasible, do not set the electric pressure above that of the mechanical, or it will flood your carburetor. That back electric pump will push the valuable fluid right on through the forward pump, even at idle.
Wm.
