just converted my 3 speed over to auto, now i need too change my yoke on the drive shaft. anybody in the so cal area happen to have one laying around.
still need one?
was your 3 spd a 2.77 or 3.03?
v8 or 6?
I need a slip yoke for a 2.77 that will fit a driveshaft from a 65 v8 mustang.
I'm in Torrance and go to Montebello for work regularly
C4 and toploader slipyokes are the same. I believe this also holds true for 3-speed transmissions in V8 cars. Was yours a V8 3-speed? If so, you might want to try the existing yoke, first.
Here is a 65 toploader yoke and C4 yoke. It possible something changed over the years. Both are 28 spline. I seen both lengths with outer or inter snap rings and 1" caps and 1.063 caps. I think Ford made more different sizes slip yokes than they made water pump pulleys.
