Re: Need Help with Hard-to-Find part
You are about there already.
I pooped out a similar one on my Ranchero two months ago. Is only a 1/2 bolt, coarse threads, and thin nut. I had to amke a few other parts for mine too. But for yours, try a piece of 1/2" water pipe as an extension and spacer.
You may need to find a shorter 1/2 bolt. The head should contact the shif linkage part, then the piece of short pipe, then the nut and screw into block, and lock with nut. You are then done. Not good looking but going in 1-2 hours. Took me that long to find the thin nut in the assorted bolt bucket.
In a month or so, once you get throroughly tired of the adapted one, purchase a correct one.
Wm.
Old Ford owner
