08-20-2007, 01:03 PM   #1 (permalink)
6bigdaddy
Question 390 truck motor
I wonder if anyone can can tell me the difference between the 390 truck motor, and if i should put one in my 67 mustang.
6bigdaddy is offline   Reply With Quote
08-21-2007, 06:36 PM   #2 (permalink)
coosbaylumber
Re: 390 truck motor
Only thing that I read (quite some time back too) was that basically the engine only came as a two barrel, had low compression ratio so that it ran on lower Oc gasoline, and the conencting rods were a bit lighter, due to it putting out lesser H.P. then too.
Otherwise using correct era applicances, it ought to go on in.
Wm.
Old Ford owner
08-21-2007, 08:57 PM   #3 (permalink)
Re: 390 truck motor
The truck engines are identical but have diffrent cam's and compression ratios like WIlly said.
I believe the rods are identical though... I'll ask my machinist tomorrow...
08-22-2007, 07:45 PM   #4 (permalink)
6bigdaddy
Re: 390 truck motor
Thanks for all your help. I think i may try and squeese it in.
08-22-2007, 08:26 PM   #5 (permalink)
My427stang
Re: 390 truck motor
Check the casting number on the heads and post it here
Depending on what it came out of, and the heads on it, you will need different headers or manifolds
No matter what, the truck manifolds will not work, so we need the casting to let you know what you need
70 Sportsroof, 427 FE/489 cid, 10.7:1,Ported Edelbrock heads, and RPM intake, 1000 Holley HP, Ceramic Hooker Supercomps, TKO-600, 3.70, A/C
Usable Truck Motor Fordota Truck Forum 4 06-07-2007 09:55 PM
what motor 1954 Ford fire truck Big Job 850??????????? ling102 Truck Forum 3 06-05-2007 09:37 AM
what is the hp of a 74 460 4bbl truck motor in a truck jtmnoxville All Ford Techboard 1 01-07-2005 08:05 AM
77 460 truck motor, into a 69 mustang fastback? galaxierace All Ford Techboard 3 09-17-2004 02:00 PM
351W into 79 truck - what motor mts stevefretz Truck Forum 7 04-19-2004 03:53 PM
