Re: sheet metal gauge help please?
I have to highly disagree.
Really that only has to do with peak ratings...
I can weld razer blades together with my HTP MIG 200, and even weld tin foil together with it setup for aluminum
I'm not sure what kind of problems you are having.
In actuality the Lincoln 100 has i minimum heat output setting of 30A DC
Whereas the later Lincoln 135 has a lower heat output setting that is only 25A DC
So the excessive heat cannot be coming from the unit itself in comparison to your 100. Sounds more along the lines of wire feed problems to me. Remember that your amps have little to do with how your welder is preforming heat wise. Most heat adjustment is done through wire speed, Gun distance and of course weld time.
Was your welder new when you purchased it?
It almost sounds as if you got excessive birds nesting in your Cable Liner, causing excessive friction for your wire feed system. and the liner may need to be replaced. And also Wire tension is also a very important adjustment. A welder even slightly out of adjustment just can't perform...
Richard
