09-13-2007, 04:40 PM   #1 (permalink)
67stang347
headers and exhaust manifolds
Are those the same thing?
67stang347 is offline   Reply With Quote
09-13-2007, 05:01 PM   #2 (permalink)
CaptVirgilHilts
Re: headers and exhaust manifolds
I guess based on what they do they are the same thing but headers are usually made of tube whereas manifolds are generally cast iron. Headers are usually designed to flow smoother than stock mainfolds thus increasing power
Stu
1967 Mustang Coupe
09-14-2007, 04:05 PM   #3 (permalink)
MidnightRider
Manifolds tend to be quieter under the hood than headers.
MidnightRider is offline   Reply With Quote
09-14-2007, 07:15 PM   #4 (permalink)
jetnoise
Nope
70 Mach 1 393W
75 Bricklin 357W
09-21-2007, 02:46 AM   #5 (permalink)
PaulS1950
AS stated above headers and exhaust manifolds are not the same but they do the same thing. Headers are used where performance is more important than noise or easy access to plugs and starter. Even factory "performance manifolds" or cast iron "headers" don't flow as well as a good set of headers. Headers can also be tuned to some extent by using a piece of tubing the same size as the collector to make your collector longer to match your cam. You can add some low end to the cam without hurting the high end. Reducers can also be made to limit the restriction and reduce the back pulse over the longest range of RPM.
Paul
390 Exhaust Manifolds 66sedan Fairlane Pages 3 08-24-2006 05:44 PM
Can you run 11.00\'s with exhaust manifolds?? 428cobra Event Calendar 1 03-29-2005 04:27 PM
exhaust manifolds.....??? NoLongerHere2 All Ford Techboard 9 06-04-2004 01:02 PM
exhaust manifolds TheUnfairlane All Ford Techboard 6 01-28-2002 10:36 PM
$$$$ exhaust manifolds? rod n az All Ford Techboard 0 01-28-2002 02:56 PM
