Re: Starter confusion?
If the throw-out bearing is squealing then you need to increase the free travel in the pedal. It squeals because it is turning without a load. When you depress the pedal it loads the bearing and then the squeal stops. Add in enough free play to the point where the throw-out bearing stops turning.
Paul
