Re: Hood Clearance?
The first question is which one do you want to run? I don't know the specifics about your engine, but generally speaking, I would recommend the Victor Jr. on a 408 unless you have a heavy car or truck.
Also, keep in mind that I have a 1" spacer under my carb because I needed a vacuum port for my power brakes. Even with the spacer my 12x2 oval was sticking up a little over 2" out of my hood. If you have a 2" scoop and no carb spacer, then you should be fine using a 2" high oval.
I believe fdnut is using a 3" high filter under his cobra jet scoop. I was going to use a cobra jet scoop just like frdnut's set up, but then I found this old Cal Custom scoop assembly and decided on it just to be different.
424W-KB Forged 10.2:1-AFR 205's-Victor Jr.-Mighty Demon 825-Comp Cams hyd roller.236/.240 .555/.576-Miller rockers-Hooker Super Comps-3" exhaust-Gene Hughes AOD-3.55 Posi-4wheel disc brakes-419 RWHP at 5700/418 RWTQ at 4500
