11-19-2007, 12:19 PM   #1 (permalink)
Plateman
5.0 + T5 in a 65 mustang
I have searched this forum and other sites but have not found exactly what I am looking for. I found tons of info and the T5 swap and info on the 5.0 swap, but have not found anything on the complete swap together.
I currently have a 64.5 Mustang with a 289 (original motor was 260)and 3 speed. I just purchased a complete engine and T5 out of a wrecked 91 mustang. I plan on installing the complete setup in my 64.5. I think I know most of the basics:
Taking EFI sytem off and going with carb.
Going with Hydraulic clutch kit.
Electric fuel pump.
I have a 28 tooth drive shaft that I will shorten if needed.
New transmission mount.
Find Headers that will fit.
Will be going with the Taurus electric fan conversion.
Some of the questions I have are:
Can I use the 5.0 belt and pulley set up (after I remove unwanted components)?
What extactly do I need to do with the oil pan?
Can I upgrade the Cam with the current set up for more HP?
Anything else?
Thanks.
Plateman is offline   Reply With Quote
11-19-2007, 02:07 PM   #2 (permalink)
tubbie50
Re: 5.0 + T5 in a 65 mustang
You can use the 5.0 pulleys if your useing the smog pump I didnot went to a 84.5' belt to 85.25 ' belt . Your battery will have to be little smaller for it will be close to the alt. I put my battery in the trunk . You need a pickup for your oil pump front type also a front sump oil pan you can allways put a larger cam but you should also upgrade your heads larger valves or gt40 heads it gets very costly and you will have plenty of power if you keep it stock . The drive shaft will need shortened Mine did and I had to change the yoke . You will have to use your stock trans mount with a after market trans cross over brace NPD or mustang unlimited has them clutch cable kit is ok with try y headers I had to bend my tubes out alittle also insulated the cable better what comes with them is not very good . Hope this helps . Jim
tubbie50 is offline   Reply With Quote
11-20-2007, 07:01 AM   #3 (permalink)
gotyurback
A C4 yoke will fit the T5 trans, once you change your oil pan from rear sump to front, you'll need to block off the old dip stick tube hole on the block. Then you will need to purchase an earlier model Timing chain cover that has the oil dip stick tube in it, or just drill your existing timing cover that on the 5.0.
1969 Ranchero 500 351W
1963 1/2 Galaxie 500 XL 390FE
1964 Comet Caliente 347 EFI
1967 Mustang 289
gotyurback is offline   Reply With Quote
11-20-2007, 08:34 AM   #4 (permalink)
Plateman
Thanks all for the help.
11-20-2007, 11:08 AM   #5 (permalink)
retroFiveOH
Electric fuel pump.
Anything else?
Thanks.
You don't NEED to run an electric pump, most 5.0L covers can be machined to take a mech. pump and the early dipstick, or as was mentioned, you can swap on an early timing cover, but you can't run a 5.0L pump with a 65-68 and some other older timing covers, it will throw off the alignment among other issues.
The C4 yoke works, someone else mentioned that, you can also use a C4 speedo gear, trans mount, and speedo cable, and buy a T5 transmission crossmember for an early Mustang. You just use regular headers for a 65 V8 Mustang. For the oil pan, you need the 65 pan, pickup and dipstick and plug the dipstick hole in the block with a 1/8" freeze plug.
To run the 5.0L belt setup, a ~60" belt is the ticket for no PS, AC, or smog. For this, you'll need to stick to a 5.0L timing cover and use different rad. hoses if using a 65-type inline in-out radiator with the 5.0L water pump.
The Taurus fan takes some doing as the mounting setup isn't meant for older cars, so you might consider something else and check the depth carefully as well as early Mustangs need a pretty shallow electric fan.
The 5.0HO pistons will accomodate a huge cam if you want.
HTH
-KD
PS: Before I forget, if you use the 5.0 heads, you'll need to plug all the different smog holes.
'66 Mustang Coupe 289/C4 HiPo cam...not in progress
'66 Mustang Coupe Explorer 5.0L, looking for a T5
retroFiveOH is offline   Reply With Quote
1964-1966 Mustang 9\" into 1967 Mustang strtcar All Ford Techboard 6 03-07-2007 05:08 PM
Mustang National Show in Mustang,Oklahoma..april 2007 98yellowgt Event Calendar 0 01-28-2007 09:19 AM
Mustang II in classic mustang engine postion justinhip All Ford Techboard 0 04-25-2006 06:55 AM
460 + Mustang II front end.../71-73 Mustang Talk MightyMach All Ford Techboard 12 03-01-2004 05:45 PM
Is it possible to put a 60\'s mustang body on to a mid 90sto 2003 mustang frame ? chris21 All Ford Techboard 12 07-09-2003 05:31 PM
