Re: t-5 confusion
You will have to get all the parts to mount a standard tranny on your Mustang - including the bellhousing for your 200. You then will have to add an adapter plate between the tranny and the bellhousing to fit your T5. You will have to use the standard clutch linkage for the 6 cyl Mustang because there are no provisions to mount a slave cylinder or cable to the bellhousing. If you drop the cable part of this tranny switch you will make it a "bolt in" job.
Try Transdapt for the adapter plate - If they don't have it and can't tell you where to get it you may have to have it made at a local machine shop. Still less expensive than $400
Paul
