01-08-2008, 09:34 AM   #1 (permalink)
DAVIDE
Question Front sway bar
I'm in the process of replacing the front sway bar. Can someone tell me if when installing the new one, is the front suspension to be under load or hanging. All the best, Dave
DAVIDE is offline   Reply With Quote
01-08-2008, 11:02 AM   #2 (permalink)
beegshot
Re: Front sway bar
It doesn't matter whether the front end has any load on it or not. The car should be level, though, or you'll have a hard time getting all of the bushings and washers over the end link bolts.
Robert
http://www.fordmuscle.com/pics/beegshot_a.jpg
Beegshot
2 - 65 'stangs, 79 F100 SuperCab, 03 Expedition
Henry Ford said, "If you find you need a tool, you have already paid for it."
01-08-2008, 06:24 PM   #3 (permalink)
iryshman
Re: Front sway bar
Davide
Couple of things that may help. First is I agree with the other poster, I've also found it best to keep the suspension loaded when replacing the sway bar and or link pins and bushings. The second thing is just a tip. If you are replacing with a bigger sway bar keep an eye on the frame mounts where the sway bar bushings bolt to the body. These brackets are thin metal and I've had them crack before after putting in a 1" sway bar. Not a big deal to fix but you will need a welder and some plate metal.
1967 Mustang Coupe
306ci with C4 automatic
8" EquaLock 3:55 Gears
iryshman is offline   Reply With Quote
01-09-2008, 07:01 AM   #4 (permalink)
DAVIDE
Thumbs up Re: Front sway bar
Thank you both for the tips.
Dave
01-09-2008, 07:03 AM   #5 (permalink)
DAVIDE
Re: Front sway bar
Thank you .
01-10-2008, 03:35 PM   #6 (permalink)
hepcat69
Re: Front sway bar
ive heard putting anti-seeze on the bushings will help with squeakin in the winter time. i used the whole tube supplied on mine and it squeaked real bad then i put anti-seeze on it and it all stopped.
hepcat69 is offline   Reply With Quote
01-11-2008, 05:43 AM   #7 (permalink)
iryshman
Re: Front sway bar
A new sway bar with urethane bushings should come with a tube of goo thats like a cross between wheel bearing grease and glue. Its real sticky but it lubricates. Put a good amount of it on the inside of the urethane bushings that mount to the frame and the sway bar wont squeak but its like any lube, too much and it gets sloppy and greasy as it works its way out along the sway bar. I've never tried that silver anti-seize but sounds like it might work too. It doesn't want to come off thats for sure.
1967 Mustang Coupe
01-22-2008, 05:33 PM   #8 (permalink)
Selector
Re: Front sway bar
I install them with the car loaded and level as noted above. As for the bar if you can set up a rear sway bar it will help handling alot. I run a 1 inch front and a 3/4 inch rear. The only issue for installation will be access if your car is lowered.
70 Boss / SCCA Solo 2
Selector is offline   Reply With Quote
04-07-2008, 04:57 PM   #9 (permalink)
BlackSunshine7
Re: Front sway bar
Is there any chance you could post some pics of your rear sway bar location. I dont want to rush in and have a clearence problem. It would be a huge help. Its a '67 mustang coupe.
BlackSunshine7 is offline   Reply With Quote
04-08-2008, 11:44 AM   #10 (permalink)
iryshman
Re: Front sway bar
If I had one I would but I don't have a rear sway bar on the '67. This post was for a front sway bar. Sorry.
1967 Mustang Coupe
Front Sway Bar, Should I take it out? Roarnracin All Ford Techboard 9 04-04-2007 01:12 PM
PST-Gmax 1\" front Sway bar ga289stocker Mustang Pages (1965-1973) 0 05-14-2006 12:28 PM
front sway bar dbu8554 Galaxie Pages 10 06-21-2005 04:18 PM
64 Fairlane front sway bar johndeere400 Fairlane Pages 3 03-29-2005 01:21 PM
Front sway bar diameter streetstang67 All Ford Techboard 3 11-27-2003 12:02 PM
Powerhouse products
