68 mustang wiring questions
Hi,
I've got two wiring questions for a 68 Mustang. First, I am installing a new ignition switch and socket assembly. My new Motorcraft socket indicates that I should have a red/white stripe wire in my harness, but there does not seem to be a terminal for this wire at the switch. The instructions indicate that this wire on the switch is not used for a number of models, but is used for the mustang. Any ideas?
Second, my car has factory air. There was a push/pull switch in the harness that turned power on and off to the compressor. This was patched into the harness, which was pretty hacked up from the installation of an aftermarket stereo. I've got the harnessback to stock configuration, but this switch does not appear in any wiring diagrams I have. Was this factory and if so where does it go in the harness?
Thanks,
John
